- May 7, 2012
- Dorset, UK
I'm going to be upgrading to a 3570k soon and I am trying to find the best cooler I can for less than about £40-£50 that will fit in my Zalman Z11 Plus. Whilst the stats say that the case is 260mm wide, the main part of the case is only 200mm wide so space is a bit limited.
I would go for a Thermalright True Spirit 140 but I don't think it will quite fit at 170mm tall, unless the cpu socket is far enough down on an ASRock Extreme 4 for the cooler to be under the window, which bulges out allowing for quite a lot more height.
Other alternatives I was looking at:
- Hyper 212 evo
- Thermalright HR-02 Macho
- Hyper 612S
