you might say lower cpu temp is a return, for what? these are safe to run up to 90c or 100 or what ever i dont remember but its well beyond what a cpu is goign to do on stock clocks or even overclocked to decent speeds. the 94c people are probably noobs who dont know how to mount a cooler.
without the IHS there to protect it there is a chance you could crack the die on the cpu.
but in the end its up to you do what you will we can make up your mind for you, just figured id share some insight from my point of view. have what you will.
You probably don't care but 100c is boiling so if your cpu is at 94c you should be going then then with an alarm screaming catastrophic failure in you face. Just saying.
still if it is geting to 100c then some thing is very very wrong. and is NOT normal. unless you are trying to wreck the thing then it is fine to have a cpu go to 100c. imho
That said, it shouldn't get that hot if the cooler is working.
and that right there is why I said what I said if cooled corectly it should not get to 100c
