Those Fans are blowing on the heatsinks, not pulling away?
In order to adhere them with the double-sided adhesive material to the heat sink with the fan housing hub, they will need to be oriented to blow down on the heat sink. You can't turn them around unless you fasten them another way.
Welll you could but the power cable would twist up might fast. Hehehe.
RGone...
Blowing on the heatsinks so the air spilling out goes over toward the bottom of the CPU as well. Especially needful with W/Cooling.
RGone...
