Ok, added the 50mm fan over the NB Heatsink and the 40mm fan over the other heatsink...
I am at 4.515 currently and temps are WAY lower.
CPU stays around 47c, and the socket temp is around 60max, usually hanging around 57-58. Yes, I am blending using Prime. Yes I have ran it at 4.7ghz just fine for hours on end... With the better cooling I think I could run it 24/7 stable at 4.7ghz on air. I am only using 3.76v at 4.515, gonna try and see if I can squeek 4.6ghz out of it on the same VCore.
*Edit*
I kinda knew it... I did some playing last night and it seems anything much above 4.5ghz requires 1.4vcore. I tried, but got Illegal SUMMOUT almost instantly. This was the same results as last night. Bumping to 1.4 and we will see how temps are.
Yeah, 4.62ghz, 2200MhZ NB, temps are around 51c for CPU and 61-62c for Socket. Much better, I think I could go to 4.7ghz and be a few degrees hotter, but at 50 degrees on the CPU, I think I am right where AMD designed this chip to be before degradation.
I am amazed at this chip. My last OC was a Q6600 and that thing ran HOT. I could barely get 800mhz OC out of it. This thing is far more capable than I am willing to push it. It would do 5ghz on air fairly easy if I was willing to let it, I would even bet 5.3ghz or so if I was willing to go to 1.6vCore.
Completely amazed. I am going to game with it at 4.62ghz and see if this is going to be my daily clock.
