- Nov 25, 2010
- york, IL
So I just order the parts to upgrade my PC from a amd 9850BE and 4gig of ram to a asrock z77 extreme 4, i5 3570k and 8 gigs of kingston hyperX.
My question is that I've been looking to upgrade my evga gtx260 to get a little more performance in that area, I'm looking to spend less that $150 to do so. The one card that I have found that seems to be the best deal to me is the 4870x2, have found some for <$100 on ebay, but have read that they are power hungery and run hot, which isn't really an issue for me. So is it worth it, or should I be looking at something else that will give me a noticeable increase over the 260, but not kill my budget or should I just stick with what I have.
Side note I did end up buying a second 260 to run sli, before I really broke down into finding something better overall in a single card layout, so would the 4870x2 still be better, or is there still something out there that can do better than 260s in sli.
