E elec999 Member Joined Jul 18, 2003 Mar 19, 2013 #1 I have a new gtx 680 and would like to know how many instance should I run on it? And how to? Does cpu make a big difference? Can I use my am2 250 x2 for this?
Voodoo Rufus Powder Junkie Moderator Joined Sep 20, 2001 Location Bakersfield, CA Mar 21, 2013 #2 How much memory on the card do you have? I found that you can run about 4 instances per gigabyte.
Clutch_Head Member Joined Feb 6, 2003 Location up state NJ Mar 22, 2013 #3 you could use monitoring software to see the load % on the GPU. running one instance on my 670 i was at around 80-85%. two got me at around 95-98%. i used EVGA OC Scanner X. dunno any others ATM.
