- Oct 27, 2008
I have had my ASRock Z77 Extreme9 for about a month and love the board but... I noticed that resume from sleep which had been working flawlessly started to hang a few times. Now when I tell the computer to shutdown, windows will indicate that its shutting down, the screen will go black but the computer stays on and the mainboard indicates error code 05 which in the manual is "0x05 OEM initialization after microcode loading". I then have to hold the power button to get it to shut off. The same thing happens when I tell it to restart. If I tell it to sleep the same thing happens except I get mainboard error code 03 which in the manual is "0x03 North Bridge initialization after microcode loading".
I started off with the latest BIOS revision and all the most current drivers for this build on a brand new SSD. The system worked flawlessly for a month before this started happening all on its own (I didn't change anything or mess with settings when this started).
I've recently seen some other posts regarding this issue but no solutions... I'm hesitant to reset the CMOS just to see if it will help because I'll have to backup and rebuild the RAID array.
I hope someone can help!
