- May 15, 2010
- Euroland, Denmark
- Thread Starter
- #61
This is my secondary rig, I got the block used, and if i change it in the future, then it will be another used one.
In all accounts Pierre its a very nice looking build, and i know you will get it sorted, sooner or later. GL to you AJ.
Is the 5.25 cover translucent?
No, just thin
You could pop it off and hit the back with a layer of primer or white paint and fix the light bleed.
I like the light though, seems to come from nowhere
Im not worried, i plan a full mesh front and later on, I plan to have a fan controller in the bay
