Good afternoon guys,
I was playing on my computer yesterday and suddenly a loud sound came from my motherboard or something which tells me if the computer is too hot. So as i heard the sound i shut down the computer and opened the case and checked whats wrong with the water cooling. I noticed that the pump wasnt pumping water anymore, which caused the computer to overheat. Then i unscrewed the pump and checked whats wrong inside, i turned the power on and as the pump started pumping it stopped after 1 turn. I did this a few times but it keeps stopping to turn after 1 turn.
I really want to get my pump working again because i need my computer for alot of school stuff.
The pump is called: Thermaltake P500 and is not being built anymore.
Regards
Regards
