- Jun 20, 2013
- The Netherlands
- Thread Starter
- #81
What are you setting at LLC NB ?My every day speed is 4.64 G I have my LLC set to ultra and Vcore at 1.45 but when under load it hits 1.474. So it's a really big jump for the next step.
My wife and I were in Amsterdam 6 yrs ago. We have relatives in the Koln area in Germany and needed a break. So we took the train for a couple days had a real blast there.
another thing that comes to mind is that he might have some how changed the test from blend to small FFT.
I use blend for system testing and small FFT for cooling system testing.
Yep, small FFT beats on the CPU and should be used for CPU testing while blend adds a lot more ram and tests the system but gets lesser temps. Been this way for years in fact.Nice call C_D someone mentioned to try that last night and it does get hotter. From the screenshot int post#81 itlooks like that's exactly what's going on.
You ready to start Oldie ?
Im just back from shopping and buy myself a present,
Guess what?
Guess = H80 cpu cooler.
You might just be reaching the limits of your cooler. Last night was probably cooler in your room than it is now in the middle of the day. Either that or your fans aren't running at max.
1.428 is not to bad.
I think johan is on the right track with both ideas.
what is your cpu/nb voltage?
what is your cpu/nb llc?
No not bad at all just the temps are getting to be an issue. I see you have lot's of fans oldie but how are they set up? Do you have 2 in front pulling cool air in with the 2 up top and rear fan pushing hot air out.? The side mounts aren't necessary and can actually disrupt airflow in some cases.
Looks like it was the NB or the ram at the higher bus speed that was the problem. But either way If we can't lower the temps we're pretty much finished.
Yes last night it was about 10 C
NB/ V 1.25v
NB/ lcc High
1X140mm front pushing
1X120mm front pushing
2x120mm left pusing
1x120mm pushing cooling 2000 rpm
1x120mm pulling 2000rpm air from cooling rear
1x 120 mm push
1x120 mm pulling
