Page 1 of 2 1 2 LastLast
Results 1 to 20 of 33
  1. #1
    Join Date
    Jul 2013
    4770K stuck at 800Mhz ?!?!?
    Hi - I've got a really odd problem with my new setup and im hoping you guys can help me out.
    I thought I knew plenty about PC hardware but this is baffling me. I've just upgraded from my ageing core2duo to a 4770k running in a Gigabyte GA-z87x-oc. For some reason the chip seems to be stuck at 800Mhz?? Ive tried default Bios settings as well as upping various settings but nothing seems to make a difference. It's as though the turbo isn't kicking in or something even when running a game or Prime95 - could it be a faulty part?
    Here's what CPU-Z has to say
    Windows 8's task manger shows it at 20% when prime95 is running but Im guessing it just calculates it against the expected speed.
    Does anyone have any ideas? My new rig is slower than my old one!
  2. #2
    Join Date
    Oct 2004
    If that is real then I would look to see if there is a new BIOS update. Download Aida64 to make sure it's real though just to get a 2nd opinion.
    New rig: INWIN D-Frame, i7 4770k @ 4.7 Ghz (no delid), Swiftech H220, MSI Z87-GD65 Gaming, Team Vulcan DDR3 1600, 9-9-9-24, Samsung 840 pro 256GB, EVGA GTX 780, Corsair 850W
    Old rig:Antec 900/GIGABYTE GA-X38T-DQ6
    E6750 @ 3.5 GHz/Thermalright 120 extreme/MX2
    CORSAIR Vengance 8GB
    PNY 8800GT/Thermalright HR-03 GT
    Old, old rig: FX-53/GIGABYTE K8NSNXP-939 nForce3 Ultra/1GB CORSAIR 3200XLPRO
    X800XTPE/WD 74GB Raptor/250GB Caviar
  3. #3
    Senior Member Knufire's Avatar
    Join Date
    Feb 2010
    Terre Haute, IN
    Benching Profile Heatware Profile
    Try disabling C-states and Intel SpeedStep in the BIOS?
    i7-920 3.8 Ghz | Venomous-X w/ Panaflo HS | Sapphire Vapor-X 4890
    EVGA X58 SLI LE | 8GB Corsair Vengeance DDR3-1600 | 500GB Samsung OEM | Rosewill 850w | Thermaltake Armor Series | OCZ Vertex 2 60GB
    Secondary Rig:
    CM Elite 430 | A8-3870K stock | Radeon HD 6670 | 500GB WD Caviar Blue | 4GB G.SKILL DDR3-1333 | ASUS A55
  4. #4
    Join Date
    Jul 2013
    Quote Originally Posted by Rob94hawk View Post
    I believe it's real, games are running dog slow and are taking nd age to start, Aida64s report gave me this:
    Processor Properties:
    Manufacturer Intel
    Version Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
    Asset Tag Fill By OEM
    Part Number Fill By OEM
    External Clock 100 MHz
    Maximum Clock 7000 MHz
    Current Clock 800 MHz
    Type Central Processor
    Voltage 1.1 V
    Status Enabled
    Socket Designation SOCKET 0
    HTT / CMP Units 0 / 4
    Capabilities 64-bit
    I did think of that but there doesn't look to be anything in there called speedstep??? the Turbo features are there (and enabled) but nothing about lowering the clock.
    This being my first chip that uses Turbo, is it normal to see it idle at that sort of speed? Or is something very wrong?
  5. #5
    Join Date
    Feb 2010
    Terre Haute, IN
    If it's not going up during Prime95, something is wrong. Speedstep should definitely be in the BIOS somewhere, that's the feature that downclocks your CPU when it's idle.
    Secondary Rig:
  6. #6
    Psyko07's Avatar
    Join Date
    Feb 2011
    Tyler, Texas
    Benching Profile
    They moved a few things around in the bios on the latest Gigabyte boards threw me for a loop the first time I saw one. You should be able to find the C-State settings under "Advanced CPU Core Features" under the performance > frequency tabs. When you disable all the C-States your CPU should be locked at its stock frequency of 3.5Ghz.
    3770k @ 4.7ghz
    Gigabyte Z77X-UD5H
    G.Skill Trident X 2x8GB @ 2400Mhz
    Samsung Evo 500GB
    Evga GTX Titan
    Corsair HX1050W PSU
    Corsair 800D
  7. #7
    Psyko07's Avatar
    Join Date
    Feb 2011
    Tyler, Texas
    Benching Profile
    Found another screen of options on the advanced CPU core features page.
    Name:  GA-Z87X-OC Advanced CPU Core Features.jpg
    3770k @ 4.7ghz
    Gigabyte Z77X-UD5H
    Samsung Evo 500GB
    Evga GTX Titan
    Corsair HX1050W PSU
    Corsair 800D
  8. #8
    Boulard83's Avatar
    Join Date
    Jan 2009
    Quebec - Canada
    Windows power state locked at lower than 100% ?
    Screen saver / power management / something like "advance settings"
    Then you should be able to change de % of power windows ask to the CPU. Min/MAX.
    Boulard83 @ OvercloQc.com
    BTTB
    • Gigabyte Z87X-OC • WCed 4770k • 2x8gb Ballistix 1600mhz cas8 • Zotac GTX 780 • Asus Xonar Pheobus
    OS Toshiba Q 256gb • Games 2x Agility 4 256gb Raid0 • Corsair HX850 • Tecnofront HWD BenchTable • Asus VE278Q 5760x1080
    HTPC • Gigabyte H77m-D3H • G2020 • NT-06 • 2x4gb Patriot Viper 1600mhz • Asus GTX 650 TI • SB Recon3D
    X25-m 80gb • Enermax 550w • Lian Li PC-C60B
    Server • Asus Z77m PRO • 2500K • NH-C12P • 4x4gb G.Skill Ares 1600mhz
    Agility 4 128gb • Corsair CX430M • 2X 1TB Black • 1x 2TB green
    KatPat • Gigabyte 990FXA-UD3 • FX-8320 • PH-TC14CS • 2x4gb Patriot Viper 1600mhz • GTS 450 + Accelero L2 Plus
    Samsung Evo 120gb • Corsair HX750 • Bitfenix Survivor White • Asus VE247H
  9. #9
    Join Date
    Jul 2013
    Thanks they all match my settings except ive disabled all of the cstate options but nothing is having an effect it still refuses to go above 800 - could it be os related? First install of win 8... grasping at straws I know but I'm really stumped
  10. #10
    Join Date
    Jul 2013
    Quote Originally Posted by Boulard83 View Post
    Thanks but I checked that too min and max are both set to 100%
  11. #11
    Boulard83's Avatar
    Join Date
    Jan 2009
    Quebec - Canada
    Great, just to make sure
    BTTB
  12. #12
    Join Date
    Jul 2013
    Just another wild guess - I'm only using the 4 pin power connector on the board, should I be using the 8? Would that even matter??
  13. #13
    Boulard83's Avatar
    Join Date
    Jan 2009
    Quebec - Canada
    Quote Originally Posted by rooster790 View Post
    Look the manual, it could be writen where to plug if you only use a 4 pin. I personnaly use a 8pin on my z87x-oc, i left the 4 pin unplugged.
    BTTB
  14. #14
    Researches Meritless
    LIES for the Front
    Page and Super Mutterator
    Overclockers.com Editor
    First Responders
    EarthDog's Avatar
    Join Date
    Dec 2008
    Stuck in Maryland...
    Author Profile Benching Profile Folding Profile Heatware Profile
    The 8 pin is the primary power source there I believe. Try that and see if it changes anything.
  15. #15
    Super Moderator
    First Responders
    redduc900's Avatar
    10 Year Badge
    Join Date
    Dec 2000
    Portland, OR
    The SpeedStep option is called CPU EIST Function.
  16. #16
    Join Date
    Jul 2013
    Thanks for the suggestions guys but still no change, EIST disabled and using the 8 pin connector now. So weird. Do you think it's RMA time?
  17. #17
    Premium Member #7
    Ajay57's Avatar
    Join Date
    Aug 2012
    Walsall, West-Midlands, UK.
    Rooster790 maybe this will help you with your Problem, i found this on the Net today!! It say's there is a switch in the Bios which is set by the Factory. This OC TRIGGER SWITCH or (TGR) is set at no 2 which Switches off all the Bios Commands and runs your CPU @ 800MHZ! To change this all you need to do is set it to NO 1 Position then the Bios will work as normal and you can Overclock your set up, Best Regards AJ.
    1, So after many hours or playing around and tweaking i finally decided to read the manual for my motherboard and found there is an OC Trigger Switch (TGR) this was set to 2 from factory when it needed to be set to 1.
    In position 2 the processor ignores all bios settings and runs using the lowest core multiplier possible which in the case of the Haswell 4770k is 8 which resulted in my core speed of 800mhz.
    In position 1 the processor functions according to the settings in the BIOS.
    TLR: Anyone who buys a Gigabyte GA-Z87X-OC Motherboard make sure you check the TGR switch is set to setting 1. Mine was set to setting 2 from factory.
    MOBO: ASUS RAMPAGE IV BLACK EDITION AC4.
    CPU: INTEL i7-4960X @ 4.4 GHZ @ 1.200 Volts.
    COOLER: Full Water Cooled Benching Station with 3 x Alphacool UT60 Rads.
    RAM: Quad Set of G.SKILL 16 GB DDR3-2133 PC3-1700 @ 1.65V. (F3-17000CL9Q-16GBZH).
    GPU:2 x EVGA GTX 780 TI 3 GB SUPERCLOCKED in SLI (03G-P4-2883-KR).
    SSD:1 x 256GB SAMSUNG 840 SERIES PRO SSD.
    HDD:1 x 750GB WDC CAVIAR BLACK SATA 3.
    PSU: CORSAIR AX1200W MODULAR 80 GOLD.
    CASE: DIMASTECH BANCHETTO TEST BENCH MINI V1.0.
    O.S: WINDOWS 7 64 BIT HOME PREMIUM.
    MONITORS:2 X ASUS VE248H 24inch LCD/LED.
  18. Thanks!
    EarthDog (07-11-13), False Christian (02-12-14), Janus67 (09-03-13)
  19. #18
    Join Date
    Jul 2013
    Quote Originally Posted by Ajay57 View Post
    Ajay, I think I'm actually in love with you...
    That's sorted it If I could buy you alcohol I would
    Guess this is a classic case of RTFM
    Thanks very much everyone for the help. Off to play with my new toy
  20. #19
    LIES for the Front
    First Responders
    EarthDog's Avatar
    Join Date
    Dec 2008
    Ajay, you bought a Z87 board and CPU? Nice!!!
    EDIT: Forget it, that was an unquoted quote.. gotcha!
    "We have more information and more ways of accessing it than ever, yet seem increasingly less inclined to do so."- Michael Wilbon
  21. Thanks!
    Ajay57 (07-13-13)
  22. #20
  23. Thanks!
    Ajay57 (07-13-13)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
