- Jun 17, 2010
- Marietta, GA
I plan on building my own res anyway so it wouldnt be a lot of extra work, but as I mentioned above, the cost of the copper would likely not be worth it for the small amount of heat dissipation.
a painted aluminum panel would be ideal because its cheap, but I am not sure that I want to risk it in my loop...
maybe I'll try it if I have leftover copper from making my waterblocks.
Have you considered doing your own acrylic? I've heard it's fairly straightforward.
