- Mar 9, 2003
Hello all, I made a new thread for this just because it seems that each overclock is vastly different, and a lot of material I was reading was in regards to "good" overclocking i5 chips. Mine does not appear to be very high on the spectrum.
I spent this weekend overclocking my computer, and things went decent until I got to tuning the offset Vcore.
Asus P8Z77-M (2105 Bios, newest)
i5 3750k
Corsair CX500M
GSkill Ripjaw X pc3 12800 (8-8-8-24 @ 1.5V)
So it is pretty clear that my i5 isn't as good of an overclocker as most. Using fixed voltages I require 1.12-1.25V to maintain 42 ratio. 1.30V for 43 ratio. I'd prefer to stay under 1.3V in all situations, so I will probably stick to 42.
I wanted to use offset Vcore, and began to experiment. To get any stability at all I need to use a +.015 Voltage. This puts my min Vcore at like .984 and max at 1.296. (Or something in that area.) In all situations any change from 75% LLC down to say 50% LLC causes problems, at least based on my current settings. If it didn't I would use this to raise the offset voltage but lower my max Vcore.
A few notable facts:
-I can't seem to change my PLL voltage. Only Option I have in my Bios is +.1V (which would be from 1.8V to 1.9V)
-Speed step enabled
-C1E, C3, C6, C state all enabled at the moment (I realize this may be the culprit)
- LLC at ultra High (75%), Fixed Freq 350, Phase control extreme, Current capability 120% (max in my bios)
From my testing at +.015V the system is very solid under prolonged Stress testing, benchmarking software, etc. At +.005V I would get some weird Chrome errors, so I upped it. At .015V I get some odd crashing of applications. (counterstrike crashes at map change only) These seem to be low load situations, which leads me to believe my min voltages are possibly to blame. Although it may also have something to do with my C states (which I admittedly do not understand)
I am trying to utilize Speed step and Offset to lower my clockspeeds/idle Voltages. This isn't so much to save power as it is just to unload the components. I will not claim to understand the benefit of C states, but as a general direction I prefer to have as many "features" running as possibly, especially since I have such a tame overclock.
Are my symptoms pointing to a common issue? What benefits do the C states give? Is there any way to control your min Vcore in offset mode with anything other than offset voltage and possibly LLC changes?
Thanks all!
i5 3750k
Corsair CX500M
-Speed step enabled
Thanks all!
