- May 22, 2012
- Jordan
Well I run an AMD version of the Antech 920 AIO on mine and it works great. Yes it's was more expensive than the "Big Air Coolers" and as stated there slight possibility that you could get a lemon where the pump is defective or it may leak thus messing up other components being worse case scenario (anyone care to show some numbers on the failure rate) but then that can be applied to getting a bad set of ram,cpu,gpu ,psu ,mb ect..defects slip through the cracks sometimes. As far as big air coolers go their not perfect either as they're big they may not fit your case especially in some cases that run side panel fans as it could make for a very tight fit or you'll need to remove them(side fans) ,they can possibly block ram slots not to mention the possibility of added stress to you mb as some can be quite heavy,in the end there are pros and cons to both. mini rant done..
