Long story short, my CPUs pins became bent after trying to place it in a faulty motherboard. (the motherboard had bits of something in a few pinholes, filling them up )
CPU is an AMD Athlon II x2 270 3.4Ghz (stockclocked)
Tried to do a home-repair (the CPUs $40 brand new, so wasn't worried) and I accidentally broke a pin off, other then that every other pin is fine and straight enough that it went into the socket and booted. attn
My question is, will this missing pin be a problem in the future? I ran prime95 for ~30minutes without any problems. (stayed around ~55degrees as well, third party fan)
Picture before repair, missing pin is one (not sure exactly) of the bent pins:
Sorry if this is wrong section, decided to post it in general CPU discussion as missing pins can be a problem for both intel and AMD CPUs.
