This is a dedicated thread broken off the discussion I have been having with Johan in http://www.overclockers.com/forums/showthread.php?t=732646&page=12
My system:
Core i5 4670k
ASUS Maximus VI Hero
8GB Corsair Vengeance 1866mhz
Corsair H100i with 2x Corsair SP 120 Quiet fans, exhausting out of top of case (Fractal Design R4)
This is the current status of my overclocking stress testing, in attempt to nail down a rock solid multiplier/voltage:
All default values set in UEFI bios of the motherboard, memory speed changed to 1600mhz to keep things low, tweaking set to manual to get a multiplier of 42x across all cores (sync all cores). Voltage set to auto.
I have been running AIDA64 with ONLY the FPU option selected in stress test, and this has been running for 8+ hours now without crashing. The hottest one of my four cores have reached is 83c to 84c give or take.
Voltage is fluctuating of course because it's on auto, and I can see it going to around 1.275 on average.
Running P95 Blend, temps stay quite a bit lower (around high end of 60c), and there have been no stability issues. With this said, should I continue benching with FPU in AIDA64, or drop everything and just test with P95 Blend? If sticking with P95 Blend, should I hop to 43x and keep voltages on auto? Try a manual voltage setting instead?
Much thanks.
My system:
Core i5 4670k
Much thanks.
