- Nov 6, 2005
So this is finally happening, although it has been planned before and never started, my first ever water cooled pc build. I have most of the components picked out, some already purchased and a few left to figure out. So here goes...
The build:
-Case: Corsair Obsidian 750D (open to other options)
-Mobo: Gigabyte Z87-X OC Force
-CPU: Intel Core i7-4770k Haswell
-GPU: undecided
-RAM: 16gb Corsair Dominator Platinum (add another 16gb later)
-P/S: undecided
-HDD: Mushkin Chronos 480gb SSD
Cooling:
-CPU: EK Supremacy Nickel/Plexi
-Mobo: Built-in (May go EK full board block)
-GPU: undecided
As for the rest of the cooling components, such as the rads, fans, tubing, fittings, fluid, res etc. I have done some research and still in the process of narrowing the choices down.
More to come soon...
The build:
-GPU: undecided
-P/S: undecided
Cooling:
-GPU: undecided
