- Oct 14, 2012
Both, temps and killawatt, then substract 20%.
Sticking with afterburner... my mining rig is only drawing 600 watts and max temp of 75C, not bad for 2 overclocked 7950s doing about 1.2 mhash
I have been flashing bioses and messing with settings off and on, all day. So far no improved results from the stilt's bioses. I haven't found one that seem compatible with the visiontek 7950. Now I guess I will try to get it back to where was before I started...
I posted over there, hopefully he will get to it eventually.
I can't believe he would do that for everyone. People can't do a search or read through the ones already done. It seems that people ask for the same ones over and over. I hope he has gotten some generous donations.
i wish I knew how to do that stuff, think if you could tune timings and stuff like that while benching?
My 280x isn't voltage locked.
which do you have? my msi 280x is locked, can't change it with msi afterburner or trixx. havn't tried the bios flash method yet.
wait wait, its not giving you a msg like now erasing bios, now writing, now verifying ? then something is wrong
plus ud need a hard reboot before you can see changes in gpuz and such
edit: afaik u can do this in gui too, if you start atiwinflash it will give u the option to load the bios image and program it
Hmmm, single card?
I always reccomend afterburner, unofficial oc, disable ulps/no powerplay support in settings, reboot and then try again.
