- Sep 7, 2013
Somebody sticky this page, I was searching for it to help a friend
Paging ZL1
I don't think we need 10 stickies in this section. If someone wants to put together a master list of important threads in one or two stickies that could be fine, but every topic doesn't need to be a sticky.
this, I too have been thinking we have a few many already
imma setup a list as Jan suggested, good idea
Ivan, do have a request for you, edit the OP and add instructions for older cards too, they're not too diff after all, make it a general flashing guide
QFT... let's get this joint organized.I don't think we need 10 stickies in this section. If someone wants to put together a master list of important threads in one or two stickies that could be fine, but every topic doesn't need to be a sticky.
Perhaps I missed it in the thread, but is there any reason that I cannot simply lower the voltage in MSI AB assuming the card supports it and just have it boot at startup with the voltage I set? Seems easier... at least for rigs with the same exact card/needs/has that ability anyway.
I have a problem. I have done everything as the guide says and everything goes sucessfull I restart my rig but run cgminer but voltage stays the same?
I've loaded my modified bios with VBE7 and I can see that VDCC is 1144. And if I try to flash it again it says "flash already programmed".
what do you mean ripping?
yes on both cards(i have two 280x)
I've got gigabyte r9 280x rev 2.0 so I think there is no switch right?yeah both have new bios with 1144 and yes both #6 and #0 are at 1144.
no I have a rig they are seperated with 10cm space. I will have 4 280x but i'm waiting for 24 pin PSU adapter.
yes i've checked with vbe7 and its the modified bios.
its just really strange this...
