- Jul 29, 2011
- Buenos Aires, Argentina
Easy procedure, specially if using Winblows and atiwinflash.
No need to make a DOS boot disk (which can be a pain atm), and works just as good
Links:
VBE7
GPU-Z
Atiwinflash
- Download and run GPU-Z
- Extract the gpu bios using the button with a bios chip.
- Create an atiwinflash folder and extract its files there.
- Download and run VBE7 and open the extracted bios file.
- Go to the powerplay tab, and change the voltage you see in the last power state (one with highest clocks) to match the previous one.
- Save the bios with an easy to remember name and copy it to the atiwinflash folder.
- Open CMD as an admin.
- Go to atiwinflash's folder (you guys know DOS right? cd.. cd.. cd atiwinflash)
- Run the following command: atiwinflash -p 0 moddedbios.rom
- After that change the -p number to 1,2,3 or whatever, to flash your cards one by one. (it's safer to do it that way, but you can also try -pa which flashes all amd cards at once)
- Try mining at your usual settings, if it doesn't hang you can let it be or try lower. I just leave my R9 280X XFX cards at 1143mv and they mine happily at 738kh/s using 210w from the psu vs 250w.
Links:
VBE7
GPU-Z
Atiwinflash
