- Jun 7, 2011
First of all, this is truly a wonderful low power APU, just perfect for my needs, there is only one small issue:
I am using the boxed Athlon 5350 cooler and it was already prebuilt. It was the easyest CPU/APU assembling i ever did, it was just a matter of min, AMD surely did a geat job in order to make it as simply as possible. The processor surely suits everything a "low profile PC" enthusiast can wish for, including dynamic clock for maximum efficiency and all the other fancy tech but i think i have to find a way on how to handle the somewhat noisy fan.
Option A: Have to find a way in order to lower the RPM, that would mean i have to use some sort of resistor so the Volt will be lowered. The cooling may still be sufficient. The question remains if the lower RPM is able to make big contribution. In term the cooler is finest junk it may not change a lot (i cant judge). But i truly think AMD was going over the top always running the fan at max speed, that APU is a 25 W TDP, not to easy to burn. Although the APU is 70 C max (and as soon as Tjunction is exceeded the clock may be lowered) but i dont think it will ever exceed 50 C, still, i lack a proof because i was unable to read out the load temps so far. Because all the tools i found such as RealTemp was not compatible and Catalyst isnt reading out temps, not even GPU.
Option B: Replace the cooler... no idea what to get instead. The heatsink should be sufficient so i only will have to get a better fan including 4 wire for controller support.
Any useful feedback?
