Hi, dudes.
I'm considering to get my first liquid cooling loop. I think the H220 is a great option, because it's cheap, comfortable and expandable. I just don't like the included black PVC tubing. I want my tubbing to look something like this:
I just want to keep cool my CPU for now, and I like that UV reactive blue.
I'm considering three options for the coolant:
1. Feser One 1 l Clear UV Blue coolant: 7 €.
2. Reusing filtered HydrX PM2 drained from the H220 + Feser View Clear UV Blue dye (50 ml): 7 €.
3. Deionized water + Mayhems biocide + Feser View Clear UV Blue dye (50 ml): 19 €.
What do you like the most?
I will try with both transparent and UV blue tubing.
I have installed some blue LED strips in my case. Like this:
Will it be enough to make my coolant/tubing react to UV or I should go for a "UV" (actually purple) cathode?
Any advise?
Thank you!
Any advise?
Thank you!
