- Jul 17, 2014
Hello, this will be the first pc that I will make myself it will be used mainly for gaming (bf4/bf3/farcry/upcomming GTA V/crysis3) on a 1680x1050 monitor, in the past two weeks I have been looking around for pc parts. I think I have come up with 2 builds that are pretty good. Since my experience in pc building is very limited I would like to have some input from the pro's around here!
My initial budget was about €700,-. I already have 2 500 GB HDD's from my old pc and 1TB is enough for me. I have chosen a couple of parts and went over it with €12,86 so I got pretty close. The builds is as following:
http://pcpartpicker.com/p/ssZqP6 (GPU wasn't available on the partpicker site)
I also made a second build with a better CPU and GPU. I was wondering if it was worth investing in these two price wise. I have to upgrade my pc later when choosing the 2nd build but parts get cheaper over the months. Concluding am I in the end cheaper off getting the first build and upgrading faster or am I better off getting the 2nd build and upgrading later.
2nd build €846,16
http://pcpartpicker.com/p/mq4923
I chose for an aftermarket CPU-cooler for 2 reasons; 1. Less noise than the stock cooler. 2. I might overclock my CPU a bit (nothing too extreme). The SSD is for windows 8.1 and programs I will commonly use, the old HDD's will be used for media and such. I wanted the pc to look good too so the parts are all blue/black/white, with the exception of the GPU which is red on the bottom which won't really show.
Any suggestions/comments are welcome!
Code:
CPU - AMD FX-6300
MOBO - ASUS M5A97 EVO R2.0
RAM - Kingston HyperX Predator Predator (T2)
GPU - MSI R9 270X Hawk
PSU - Corsair CS550M
CPU - Cooler Master 212
SSD - Crucial MX100 256GB
Case - Fractal Design R2
2nd build €846,16
Code:
CPU - FX-8350
MOBO - M5A97 EVO R2.0
GPU - MSI R9 280X
PSU - Corsair CS650M
