So this is uhh quite interesting. Basically I have laptop that is overheating, I have it on a cooling pad but its not getting enough airflow under it. So what I am looking to do is to build a custom cooler using spare stuff I have laying around along with buying a few things.
I am wanting to have some sort of metal frame that is at least 16x12x4. The height can be changed to support fans but the other dimensions cant go small. I am willing to repurpose something to make the frame but idk what quite I could use. I am also wondering if they have any switches to short a PSU on with. From what I understand it can be done with a wire, but I would like an easy way to switch it on/off whenever. Any suggestions for parts would be greatly appreciated.
As a note, I have propped my current cooler up with random stuff and did notice about 5 degrees celsius drop so I know there is some improvement that can be accomplished.
I found this, but from what I tell it has to be held down to keep the PSU on.
http://www.frozencpu.com/products/9...le_with_OnOff_Switch_KM-03.html?tl=g12c133s88
