- May 9, 2011
- Alberta, Canada
I'm looking to do an ITX watercooled gaming build and was hoping to have a few questions answered before commiting to a case.
I'm hoping to have the equivalent of 2 x 240mm worth of radiators inside, but I'd also like to have an optical drive in there as well. If I were to use both a top and front mounted 240 rad, that only leaves a shallow 5.25 bay (enough for a fan controller and not much else).
Does anyone know if a 240mm side mounted radiator bracket (http://www.caselabs-store.com/s3-120-2-140-2-radiator-side-mount/) would work with the windowed/ventilated side panel (at the bottom)?
Or if I mount a 120 rad in the front and back of the case and 240 in the top, would the top and back interfere with each other? I'm only going to be using 30mm thick rads.
Bonus question: Say I'm looking for a custom color, does Case Labs do custom colors or will I need to powdercoat it elsewhere?
Thanks for the help and apologies for all the questions. I've asked Case Labs but they have yet to respond (and I'm a tad impatient...)
