So, here we go people, I have decided to make a work log of my phantom 410 custom loop and eventually some modding too.
First things first, I have ordered an EKWB 2.2 x-res combo, with a preinstalled pump, and all my compression fittings needed (hopefully). Also got myself some water for the loop. Which means, i have not yet got all the cooling products, but i wanted to start anyways, cause i have some measuring to do, also you can see the case as of now.
This is my first work log, so no hate, i try my best!
Reason for doing this work log: Not seen many phantom 410's with custom watercooling and atleast not many worklogs, so i hope this may be a good one, to start the **** off, and show that it's possible!
Will post pics off the computer as it is now, later today, and maybe also some other stuff, so don't go anywhere!
Last but not least, system specs, and watercooling gear:
PC SPECS:
CASE: NZXT PHANTOM 410
MOTHERBOARD: MSI 970A-G43
CPU: AMD FX4350
MEMORY/RAM: 8GB DDR3 1600gHz Kingston HyperX Na'vi limited edition (dont know what ram type, package says nothing, hmm.. )
GPU: MSI GTX650 TI BOOST with twinfrozr.
PSU: Corsair RM650W Modular
HDD: Seagate Barracuda 1TB
For fans i go with 2x140 Corsair AF Blue LED, 4x120 Corsair AF (3 with blue LED's) and one nzxt 120mm that came with the case, very good to be stock, afficient and silent
Also have individually sleeved cables from Corsair.
WATERCOOLING:
RESERVOIR/PUMP: EK 2.2 x-res pump/res combo
RADIATOR: Alphacool NexXxos ST30 240mm
CPU BLOCK: Alphacool NexXxoS XP³ Light
TUBING: Masterkleer tubing 13/19mm 1/2 -3/4 inch tubing in BLUE.
Also last but not least gonna go with compression fittings from ekwb
See you guys later, thanks for checking out!
Please recommend thing i should do better!
ALSO, IS THERE ANY WORK LOG THREADS?
PC SPECS:
CPU: AMD FX4350
WATERCOOLING:
