- Jan 10, 2012
I only use colored tubing, distilled water and biocide. Done and done
Never used it, never will. Once a year cleaning the crap out of my loop is enough for me. If you want flashy, lights are more than enough. I see no reason other than showing off to add dyes.
I tried Dead Water for a while until I found blue crystals gunking up the pins of my water block.
Yes it does, but DYE isn't one of them...
I guess if you count the olden days of pond pumps, heatercores and a dash of anti-freeze, it had dye at one time, but never since then.
