- Jan 5, 2005
- Ormond Beach, FL.
Forget about a flow meter and water temp monitor. I have never cared about either. Plug the PWM into the fan header and make sure the pump is running. That's all you need. The difference in water temp between the hottest and coolest water is like .5c. It doesn't spend a second anywhere in the loop. As long as you are happy with the temps of the CPU and GPUs, that's all that matters. I have the Malestron V1. The wires for the temp probe came out of the molex connector, so I just cut them off.
