Hwbot's Rookie Rumble is an ongoing series of competitions. It is for new hwbot members only.
New rounds of rookie rumble are under way. Post up if you want any guidance on improving your scores.
If you are new and have an Intel CPU: http://hwbot.org/competition/rookie_rumble_9
There is also a seperate competition for AMD owners: http://hwbot.org/competition/rookie_rumble_amd_6/
If you are interested in competing in the Rookie Rumble post here for any help or tips.
The Rookie Rumble Cup is here to help you get familiar with overclocking at HWBOT. The competition is limited to rookie overclockers just like you. That means you will not have to deal with the experienced overclockers just yet. The competition is typical for HWBOT. There are three stages, each with the same hardware limitations but featuring a different benchmark. The three benchmarks are: XTU, HWBOT Prime, and SuperPI 1M. You can gather points by submitting in each of the three stages. The better the result, the more points you will obtain. And eventually the more points, they higher you'll rank!
The Rookie Rumble for AMD is here to help you get familiar with overclocking at HWBOT. The competition is limited to rookie overclockers just like you. That means you will not have to deal with the experienced overclockers just yet. The competition is typical for HWBOT. There are three stages, each with the same hardware limitations but featuring a different benchmark. The three benchmarks are: CPU Frequency (% OC), HWBOT Prime, and MaxxMem Read Bandwidth. You can gather points by submitting in each of the three stages. The better the result, the more points you will obtain. And eventually the more points, they higher you'll rank! Note that for the two multi-threaded benchmarks we rank you by the score per core count. So even single core owners can compete.
