Hi,I have an Inwin Grone case with 7 120mm fans,I've tried to show on a picture below their orientation and direction.
My CPU tempratures idle in the 38-40c region,It's an i7 2770k running at 3.8Ghz and my GPUs idle at 40c,under load one GPU will max at about 70c and the other about 50c,the CPU won't climb above 70c while under 100% stress.
I am concerned that the fans are blowing air onto the radiator as this air is warm (am I right?) and could be heating the radiator up instead of cooling it down?
I have an option of adding another intake fan on the bottom of the case next to the one I already have installed
