I am planning a single loop system with two D5 pumps in series and 4 x 120.4 radiators. Only GPU's and CPU will be cooled. I will have an Aquaero 6 to run fans, pumps and lighting.
Now... I was planning to install a temp sensor as part of the pump top. The loop sequence that is simplest to route and would look the most clean is reservoir > pump -> GPU's -> CPU -> radiators. Now, ideally I would have liked to go to the CPU first and not the GPU. I was thinking that if I install a second temp sensor in between the CPU and radiators I can use the delta T before and after the radiators to adjust my pump speed. The higher the flowrate the smaller the temp difference should be at any point in the loop. I would probably top the pump rate at a certain % of max rpm though, just not to stress the system too much (the pumps themselves adding heat, plus increasing the pressure in the system).
What do you think?
What do you think?
