lbarstad
- Sep 18, 2014
- Bergen, Norway
Hi, i have a old asus mobo and phenom x6 1075t that had a mild oc at 3.6, then just randomly checking something in the bios, i saw that the oc was gone. Haven't flashed bios or done anything to it, but thats not the problem. The problem is that i can't change the cpu ratio or the bus when i change the ai oc tuner in the bios to manual, when i apparantly could do it before the clock disappeared. Only hw i have changed since i clocked it is the case. I'm fairly new to this oc stuff, so be gentle with me . Anyone have a clue what has happened?
My specs are:
Windows 7 Ultimate 64-bit SP1
AMD Phenom II X6 1070T
Thuban 45nm Technology
16,0GB Dual-Channel DDR3 @ 668MHz (9-9-9-24)
ASUSTeK Computer INC. M4A89TD PRO USB3 (AM3) 30 °C
SyncMaster (1920x1200@60Hz)
3072MB ATI AMD Radeon HD 7900 Series (XFX Pine Group) 43 °C
111GB Crucial_CT120M500SSD1 ATA Device (SSD)
Thanks
Lars Barstad
My specs are:
Thanks
Lars Barstad
