I plan to purchase a Cosmos II case and install a Noctua D-15 air cooling unit. At the same time I was thinking of replacing some of the case stock fans with Noctua NF-F12's for quality and noise reasons. However, I have read that the Noctua NF-F12 fans come with a four pin connector that is incompatible with the three pin fan wires found inside the case. If I want to use the case's fan control system am I precluded from using the Noctua fans? Or is there a way to use the Noctua fans with the case controller?
Second question please. The motherboard is going to be the Asus X-99 Deluxe with seven fan headers. Is it preferable to hook all my fans to the motherboard headers and control them through the Asus motherboard's software and bypass the case fan controller altogether?
Any comments would be much appreciated. Thank you.
