Hi All, first time moving to a custom loop after many years on AIO's. Finally took the plunge and have installed my first loop which is a EK-DCP 2.2 Pump with a Alphacool ST-30 240 radiator and a EK Supreme LTX block (went for a low cost option) on a i7-4790k. I used to have the Corsair H100i in push / pull but with this setup the I have just gone push as the temps have been better than the H100i... I have been stressed for nearly three days worrying about leaks... I will be changing the coolant or maybe tubing to white next. Happy with the temps as the CPU under p95 now doesn't go above 65 degrees and idles in the low 20's so will now start to push the CPU... If you guys can tell me if I am doing anything wrong or perhaps some advice, plead do give it.
