- May 16, 2013
- East Coast
Since all my new parts will take a while to come back after the initial X99 disastrous experience, I will have a bit more time to upgrade my rig. So, I thought that is the time to go full custom.
Now I will cool just the CPU, but my goal is to cool the GPUs when EVGA will send me the 980s. My specs are below. Just consider a potential 3rd 980. I also value noise over pure performance. I don't really have a budget limit, but I don't want to spend a fortune.
What I would buy now
CPU Block: EK Supremacy EVO (like Nickel, but people seems to suggest copper)
Radiator: NexXos UT60 360
Fans: 3 x NoiseBlocker NB-eLoop B12-P (only pull since I read that the Phantom cannot house a UT60 in push/pull)
or
Radiator: NexXos XT45 360
Fans: 6x NoiseBlocker NB-eLoop B12-P (in PP, should fit)
or
Fans: 3x NoiseBlocker NB-eLoop B12-P (push) and 2x NZXT FS-200 (pull)
Reservoir: Koolance RP-452X2
Pump: Koolance PMP-450 or Swiftech 655 PWM
Tubing: PrimoFlex Advanced LRT 3/8 x 1/2
Fittings: Monsoon Free Center Compression Fitting 6 Pack 3/8 x 1/2
What I would buy later
Radiator: NexXos UT60 240
Fans: 2 x NoiseBlocker NB-eLoop B12-P
Pump: 2nd pump?
Other fittings, other tubing(?), GPU blocks (EK or XSPC?)
Opinions? Are there any terrible mistakes?
Thanks!
or
or
Pump: 2nd pump?
Thanks!
