Hi all!
Been out of the game for a while, finally decided to get back in. This time I am going to try watercooling!
I have done some reading and decided to look at the following parts for my build. Please let me know what you think, if there is something better, or if it will work:
Current System:
CPU: i7 920 (not overclocked but planning on it)
Motherboard: EVGA x58 SLI LE
Case: Coolermaster StormTrooper
Planning on hooking up like this: Pump/Reservoir > CPU > Radiator and then back to the Pump/Reservoir
Parts:
CPU Blocks
EK Supremacy EVO Universal CPU Liquid Cooling Block - Full Nickel CSQ
or
Heatkiller Rev 3.0
or
Apogee XL
PUMP
MCP355 + XSPC Acrylic Tank Reservoir for Laing DDC (Multiport)
RADIATOR
MCRx20-XP "eXtreme Performance" Radiator Series (Triple 120mm)
TUBING
XSPC 1/2 ID, 3/4 OD High Flex 2m (Retail Coil) - RED/UV ORANGE
FITTING
XSPC G1/4 to 1/2 Barb Fitting (Chrome) (6 of them?)
I will not want to be doing watercooling for my GPU at the moment but maybe in the future.
Are there any parts im missing that I need?
Any feedback would be appreciated! Thanks!
Current System:
Parts:
CPU Blocks
or
Heatkiller Rev 3.0
or
Apogee XL
PUMP
RADIATOR
TUBING
FITTING
