http://www.techpowerup.com/reviews/Corsair/Hydro_Series_H105/6.html
Another benchmark review with the H105 Included
the Corsair H105 seems pretty damn good for a closed loop setup
The original question, 'what's the point of a closed loop water cooling', has a really simple answer: to cool system components. Closed loop cooling is simply another method. Air cooling, full custom loops, or mounting your components on the surface of Pluto all would be attempts at lowering the temps of a functioning PC.
The posts in this thread pretty much cover the pros and cons of closed loop coolers but there comes a point in the decision making process where you must ask yourself, "do you feel lucky punk?" Dirty Harry's antagonist wasn't so lucky, but perhaps counting shots fired wasn't one of his strengths. The folks building custom PCs have plenty of experiences answering the questions related to their systems, but it seems that Cold Hard Facts, data, are what the OP wants to make a judgement upon, not luck.
I've had success with all three methods. They all have cooled my PC components quite well. I took a real chance when I ran my first custom loop. But after getting over the fear of electrocuting my components with water, I had achieved better cooling than stock. Same happened when I went out on a limb and mounted the first AIO to a CPU. The mere fact that there are hundreds of heat sinks to choose from that move heat away from components says that market has matured, everyone that makes them must be making some profits in order to continue, and the AIO and Custom folks must be getting similar customer support. It's all good. What's right for you?
Ill take good air over a closed loop any day of the week.
My last closed loop was antec 620 thats surface was not flat,even after 3 RMAs, CPu would heat up into 80s at full load. What piece of crap, they were new revisions, the first revision was ok. Not as good as xigmatek darknight II air cooler though. That thing amazed me for 44 bucks. Never went above 52 degrees load
That's an AIO meant for lower end cpus. While I do not know what cpu you have, if you really want to waste money on an AIO, I generally advise grabbing an H100 or similar (1250 for Antec) for optimal temps from "liquid cooling".
Yeah I knowit was aseteks you just reminded me of the exact name.I mentioned the H100 was an AIO On that note also, Antec are simply rebranded Asetek units similar to any other company for the most part, that is not what we are discussing though.
It doesn't matter what a cpu purchase may "come with", I would never run a higher end AMD cpu on a a budget AIO cooling solution. If I were to go AIO at all, it would need to be H100 or similar units unless I were running a lower watt chip. I prefer the custom loop route myself, but I do see the convenience of the AIO units despite their lower quality parts.
There's nothing wrong with running a lower end unit I suppose, but I wouldn't do that on my chip personally. I would sooner hook back up my Noctua D14 or Phanteks TC14 and get better thermal performance.
