I have a gigabyte 750 ti card that I´m trying to overclock. I have reached max clocking at the stock voltage setting which appears to be 1.181V under load. My problem is that I am unable to increase the gpu voltage. I have tried with MSI afterburner, nvidia inspector and gigabyte OC GURU 2. I can change the value for the core voltage in these programs but when I put the card under load it still goes up to 1.181V no matter what values I put in.
As the TDP was on 80-90% most of the time peaking up to max 96% I did not think the power limit was any problem. But still I have increased the power limit in the BIOS with kepler bios tweaker from 46.2W to 65W and flashed the card. But still I cant alter the core voltage with any program it´s fixed at 1.181V under load. I have also extracted the bios after the flashing to check that the flash was successful and it was. The only difference is that TDP in gpuz now show 50-60% under load compared to before when it showed 80-90%. But at least the power limit should not be any problem now.
I guess I have to alter the voltage table with kepler bios tweaker but I cant really figure out how that one works. There are two columns and there is only values on some clocks and I cant find any relevant values equal or close to 1.181V.
I have been reading up on the kgb tool as well but I don´t really understand what voltage that tool changes? Is it the maximum or sets a fixed voltage used all the time no matter what the load is?
Is there any kind soul out there who can help me proceed because I have been trying to increase the voltage for two days now with no luck .
Here is the TDP values I changed with Kepler bios tweaker (the added text in the pictures is Swedish because I have tried to get help on a Swedish forum as well but no luck yet):
Here is the voltage table were I think I have to change something to get the card to run at 1.2V under load, but I can´t figure out how it works with two setting for each clock or multiplier and there are only values for some of the cloks/multipliers:
And here is my target that I want to increase:
