i bought the EKWB L240 kit awhile and now i want to add in another rad probably a 360/420mm and a gpu block for 970 . i have 3/8 5/8 ek tubing with ek compression fittings . also have a kill coil
will the pump (dcc 2.2 ek ) that came with the kit i bought will it be good enough to have all that in 1 loop or will i have to buy a standalone pump .
these are my specs
right now i have res > pump/res combo > cpu > rad 240mm > res
i want to do it res > pump > rad 240mm > cpu > gpu >rad 360/480mm >res
if i need a new pump is this a good one pump
should i got with variable speed control or non speed control ?
if i run the return not into the side but into the top of the swiftech micro res will the top part of my loop drain from the cpu/ rad up from gravity and will that cause problems? .since it would be less tubes i dont have to run around the gpu then back around it .
and if i wanted to add in a drain port since i dont have one right now. what do i need to add one does anyone have suggestions for tubing, are all the tubing plasticizer free now ?
these are my specs
