- Jan 9, 2012
- Massachusetts
Ok so as title says I am not a big wifi fan I like stuff wired. So I have the one network cable coming in my room for my computer which also has my smart TV I just got a few months ago. For the most part it works fine. Sometimes though when I want to watch movies on Vudu in HDX I get interrupted sometimes, signal not strong enough on the wifi to stream the amount of data needed for HDX.
What I want to do is just get a cable running into my TV as well, Do I need to get a small router ? or switch ? or can I just get something for RJ45 cable that will divide the signal without running more cable ?
Thank you
Thank you
