- Dec 10, 2013
HELLO,
looking for some advise on a new setup(cooling wise) have used self contained unit with good success, this will be my first custom loop,
i have read the stickies on water cooling, understand most of it. have a few questions,
1 is it worth going with push/pull on the rad fans or just use push, extra money for fans is not a problem
2 will the two rads i have selected be enough, not sure if figured it correctly, extra rads can fit in the case
looking for a quiet setup, used 120.1 per 100 watts(i think i may be short)
3 should i use one loop or two (cpu and cards on seperate loops)
4 if one loop is perfered, one pump or 2 in series
plan on using acrylic tubing
part that are to be water cooled(except case)
case labs magnum sma8 http://www.caselabs-store.com/magnum-sma8/
ramage v extreme motherboard(may go with a ek mono block if one becomes availble)
no liquid cooling on the ram chips
intel core i7-5960x (rounded up to 200 watts)plan on over clocking would like to hit close to 4 megs
asus strike 980 graphis cards X3 ( about 300 watts per card if i read the specs right)
rads:
http://www.frozencpu.com/products/2...Full_Copper_-_Black_35228.html?tl=g30c95s1148
http://www.frozencpu.com/products/2..._Full_Copper_-_Black_35227.html?tl=g30c95s570
any help would be greatfull, thanks
rads:
