Hippogriff Member Joined May 16, 2013 Location East Coast Nov 22, 2014 #1 I have the EK Link with two ports in the front, but I see blocks with ports on top and bottom (see pic) Is it possible to put something like that in mine?
OP Hippogriff Member Joined May 16, 2013 Location East Coast Nov 23, 2014 Thread Starter #3 EK Luc said: What's your GPU block? Click to expand... Gtx 980 original CSQ nickel Last edited: Nov 23, 2014
EK Luc Registered Joined Nov 5, 2014 Nov 23, 2014 #4 Hippogriff said: Gtx 980 original CSQ nickel Click to expand... Sadly it's not compatible since it's 2 different style of blocks
OP Hippogriff Member Joined May 16, 2013 Location East Coast Nov 23, 2014 Thread Starter #5 This is not the same? I mean being able to avoid angled fittings http://www.ekwb.com/shop/ek-fc-bridge-single.html
EK Luc Registered Joined Nov 5, 2014 Nov 23, 2014 #6 Hippogriff said: This is not the same? I mean being able to avoid angled fittings http://www.ekwb.com/shop/ek-fc-bridge-single.html Click to expand... Of course this one will work with your style of block I thought you wanted to put the precise terminal on the picture
