- Jan 29, 2012
Has anyone experienced this issue. A family member was having a issue with windows not posting every time from a cold boot. He would hit restart and then the computer would post the second time. When I first looked at this system it seemed to running ok. So I first downloaded a few programs CPUZ , HWMonitor and Prime 95. I did notice from CPUZ that the ram was running 1600mhz.
System Specs:
Asus Sabertooth 990fx
Amd 8320
GSkill Ripjaw X DDR3 ( 2X4gb ) 1866
Corsair AX 750w
Corsair H100I ( 4 fans in push/pull )
HAF 932
Again after seeing that it was running at 1600MHz I checked bios and everything is stock and set auto. I manually set the ram to 1866MHz , Save and restart. The system would not post. I cleared Cmos and tried again, still would not post. I then put the ram back to 1600MHz and system restarted fine. I then just wanted to see if the system was stable and ran Prime 95 for 1 hour with not errors or dropped cores all temps were fine.
I then ran windows memory tool, the computer shutdown before finishing. This pointed to memory issues. I have not at this time removed all but one stick and run memtest 86 an each stick. That will be my next step. I am just wondering if this maybe a deeper issue than just the ram, ( Motherboard or CPU ). Was just wondering if this has happened to anyone else and found out it was not the ram causing the problem. I would also add this system is only 6 months old and new OEM Windows 7 pro.
Thanks
jshake
System Specs:
Amd 8320
Corsair AX 750w
HAF 932
Thanks
jshake
