be quiet! Silent Wings 2 any1 have them??
matt2950
wales, UK
does any1 have these fans? im looking at the 120mm, 1500rpm at 15.7db, 50.5cfm
cheapest i can find them is £15 each and im looking to get 3-4 of them so wanted to see if their as good as the specs suggest before i drop £50 on them.
also has any1 tried them on rads? static pressure about 1.6 which seems decent.
No fan makes only 15.7 dB at 1500 rpm. The air alone makes more noise.
Yate Loon Lowspeed fans go about that fast, and are so cheap you can buy a few extra, use the best and have a couple of spares.
Yate Loon nearly 30db at 1300rpm too loud for me, low noise is priority, dont need huge airflow
