- Dec 10, 2014
I'm fed up with chunky air coolers and have decided to delve into the dark arts of watercooling to get my OC back. I've been reading everything I can but have to say I'm getting a bit lost in all the info. Looking for a little guidance with a build for this system:
CPU: i5 2500K @ Stock w/ BeQuiet Dark Rock Pro (Temps 46C Load)
m/b: ASRock Z68 Fatality Pro Gen3 Temps 40C Load
RAM: 8 GB G.Skill 2133 @ CL9, 1.65V
VGA: 2 x Sapphire HD 6950 Dirt 3 (Temps 80C/70C)
PSU: Corsair TX850
Case: CM HAF-932
RAD: The XSPC RX360 V3 seems to be the best
RES/PUMP: Unsure
CPU Block: EK Supremacy EVO
GPU Blocks: 2 x EK Thermosphere
m/b Blocks: Unsure
Questions:
1. What is the best pump/res for the job? Are 5.25" Bay RES/PUMP Combos as good? I expect I'll need a lot of flow for the 3-4 components.
2. Would this setup suffice?
RES-PUMP-360RAD-CPU-VGA1-VGA2-RES
or do I need to add another rad in there?
RES-PUMP-360RAD-CPU-140RAD-VGA1-VGA2-RES
3. Is there anything I can do with this board's mosfets and nb/sb (4 areas)?
4. Do offer suggestions/alternatives if you have any!
PSU: Corsair TX850
Case: CM HAF-932
RES/PUMP: Unsure
m/b Blocks: Unsure
Questions:
