The review left me with a few unexplained questions in regards to the PCIe layout.
-How does the lane distribution on the motherboard change with a 40-lane vs a 28-lane CPU? 5820k is by far the most popular CPU to go with x99, so this is very relevant. Many boards have their lanes setup in such a way that you CANNOT do 3-way SLI with a 28-lane CPU, but some do allow 8x/8x/8x. For a gaming board, knowing if you can do 3-way SLI or are limited to 2-way SLI is pretty important.
-Which PCIe slot (if any, and aside from the 1x slot) comes off the PCH?
-Are any slots disabled in certain configurations? This question relates to the previous two. Out of the boards that can do 3-way SLI with a 28-lane CPU, many will disable the 4th CPU-based slot in an 8x/8x/8x configuration. Only problem is that in a 3-way SLI config, that can mean your only available slot gets disabled, preventing the use of an addon PCIe card (soundcard, PCIe SSD, etc). It is important to know if that last slot is coming off the CPU or PCH, and if it is coming off the CPU, is it enabled or disabled in an 8x/8x/8x config? This is particularly important for this board, since it lacks an M.2 slot, a PCIe based SSD would be your only equivalent alternative.
