- Dec 27, 2014
- All over the place
I'd like to thank you in advance for taking the time to read this thread, for your advice and support
Since this is my first attempt at water cooling I was going to go down the All-In-One route, but figured that would be a pretty dumb choice as I would probably learn little from the experience. So, custom loop it is - which does excite a bit! lol
Everything will be going into a Phanteks Enthoo Primo
I have not bought anything yet. Please advise if you think the following basic rig is not well matched as it will (probably) be:
I definitely will be overclocking. However, it is also essential that the rig is as quiet as reasonable possible. I am literally at the planning stage (for about the last two weeks) although I will be buying the basic rig next week.
Initial questions:
Please feel free to rip this post to pieces if anything I've typed seems absurd. I'm here to learn and won't be offended! Gentle flaming is acceptable, just please accompany the flame with something constructive too lol
These are just my initial questions. I pretty much already have a list of cooling components I want, but don't want to get anything delivered that doesn't work as that would leave me feeling a bit when I want to be feeling . There will be plenty more questions coming in the following weeks/months!!!
Thanks again
- Gibabyte Z97X Gaming G1-Wifi BK (I might as well watercool the VRMs on the board too)
- i7 4790K
- EVGA 970 GPUS Reference boards in SLI
- Corsair AX PSU (Wattage to be calculated)
- Kingston HyperX Savage DDR3 modules
Initial questions:
- Is it okay to use barbs without clamps? I was thinking of using 1/2" ID barbs with 7/16" ID Primochill Pirmochill Advanced LRT tubing. I'd heat up the tubing to fit. Will that work without leaks? (I've read somewhere that it's fine but wanted to know your experiences with this). It would leave the loop looking clean without the expense of compression fittings.
- I've been doing some reading on radiator choices. If I have understood correctly a thick radiator with a low fpi will allow me to have my static pressure fans running at lower rpms, lower noise whilst still providing highly effective cooling. Is that correct??? If so, would either the 2xAlphacool UT60s or 2xBlack Ice SR2s be a good choice??? Maybe a Monsta and a UT60 if the Monsta fits ok? I plan to have something like 1x420 & 1x360. The rad sizes will be firmed up once the basic rig is installed and I have calculated how I will use the available space.
- Blocks - EK Supremacy EVO for the CPU and Heatkiller GPU-X3s for the 970s. Are these all okay? If not the Heatkillers then I could go EK GPU block solution instead.
- Do I have to use a third-party SLI bridge or can I simply connect using the same Promochill LRT flexible tubing as that will help me to maintain the colour scheme? I plan on testing the link in both series and parallel to see which one gives me the best temps. Using the tubing would also make this simple (I think) *tee-hee*
- Are the blocks and rads ok together?? They've all got to be the same internal material yeah??
- Choice of D5 pump to be decided after rads are confirmed.
- I plan to use a tube reservoir but am confused with regard to capacities. Does a res capacity make any difference at all or is it purely about what fits in the case? Reservoir may be mounted with velcro.
- Is there anything important I've missed, not considered or thought about?
Thanks again
