- May 26, 2003
Testing my 7yr old Corsair since I had a HDD die after I powered on my PC, I noticed I had voltage spikes for a fraction of a second after turning on the PSU when testing with a multimeter. All voltages were within tolerance but the 5v jumps up to 7v and 12v jumps up to 17v. Is this just an anomaly with my DMM? I don't normally use a DMM so maybe this is normal for them when calibrating voltage, I don't know. The PSU's in a non-mission critical PC and I'm using a backup PSU at the moment. I'll check to see if the DMM spikes with the backup PSU and update in a moment.
Edit: My other PC seems to have those same spikes unless I do a quick power on/off with the PSU switch. Maybe it's just an anomaly with my DMM or perhaps something common to most PSU's? Maybe the VRM's in the PSU take a fraction of a second to kick in?
Edit 2: After reading a couple Tech Powerup articles and the section where they review turn-on transience of the PSU's, I'm going to assume it's anomalous behavior of the DMM. Antec may not be what it used to be but the Antec Trio I have, I read, was made when they used quality Seasonic components so I'm assuming both wouldn't spike this much.
