- Dec 1, 2007
- Near Toronto Canada
If you really want to do that, I'd start a separate thread. That way, future searchers will be able to find the information more easily.
That said, are you sure you want to go that route?
If ITX is something you really want, I think it'd be a better idea to go with the 980 now (which will get you closest to 144 FPS) and upgrade the card down the road. Entirely up to you, of course, just wouldn't want you to completely give up on what you want just because you might have to swap out a graphics card in a year or so.
2 970s will get him to 144Hz a heck of a lot better than 1 980 will. I think he's chosen wisely. What does it matter the form factor of your PC if the output isn't doing what you wanted when you built it?
But yes, start a new thread with a link to this one.
