- Dec 27, 2014
- All over the place
Hi
Right, still waiting for the Phanteks case RMA which is good. It means I have plenty of time for extra research and planning.
Radiators & Fans
Definitely having 1 x 360 UT60 but can't decide on the second rad. Whether to have a second 360 or go with a 420. I mean, for the 360 I've got a choice of the AP-15 or an eloop (probably going to go with eloops as EUR exchange rate means importing and shipping is less expense than the Scythes). But I can't find a 140 fan for a 420. The only one that really interests me is Noctua NF-P14s redux-1200. Is that any good for a rad? Anyone here used it for their rad and can share their experience please....Are the benefits of having the bigger surface of a 420mm rad negated by the lack of available 140m quality fans, or is it still worth the investment?
As far as the eloops go, I plan to have them push/pull and to have about 2mm of decoupling material to hopefully prevent the pull fans from hitting the rads fins and making a noise. Does that work??
Enclosure Airflow
I'm a bit confused with this and sorry for the totally noob question. Typically, although it varies from build to build, I tend to have a very slight negative pressure inside the case to encourage cool air to enter the case. Now, where I'm confused is the way the airflow moves through the case as I'm going to have a rad at the top and at the bottom. This is my current thinking:
Intakes:
* Front panel (at the bottom)
* Case floor intake passing through bottom rad
Exhausts:
* Rear panel (at the top)
* Case top exhaust passing through top rad
Does this cause a problem? Don't I always want cool air from outside passing into the top rad and into the case for best cooling loop temps? But won't that disrupt the general airflow of the enclosure and go against just letting the heat naturally rise and leave the case of it's own accord? What way is generally the best for keeping both internal case temps good and cooling temps at their best please? This has kinda got me stumped and all spun around (it is quite late now). I know I can experiment to see what works best for my setup, but just wanted to know if there was a general rule of thumb.
Thanks in advance...
Radiators & Fans
Enclosure Airflow
Intakes:
Exhausts:
